Highatop
- Florissant, Co.
Ok, not sure but, Is BPM the same for us H3s as for H1s BTM? Brake and gas petal to stop wheel spin, right or wrong?
Yes, same procedure.
Brake pedal modulation?
Desert, I think we're talking about pressing the brake and the accelerator at the same time, thus manually applying the brakes to limit wheelspin. And by applying the brakes, you automatically override the traction control. So, if the OP is talking something else then I could be way off base.Hate to disagree with you. But the H3 is different. On the H3 you hold the RPM at a steady rate and traction control will sense the the wheels slipping and start pulsing the brakes. Can't remember the RPM off hand. Someone help here?
Oh my....Pandora's Box has been opened....again.
Ok, we can close the box. Just came up in a reply. Thanks
Yes, I knew exactly what your talking about. And yes you can BTM a H3. I was trying to point out you don't need to. The H3 will see the slip and start applying the brakes automaticaly. All you have to do is hold the RPM steady. IMO it works better if you let the truck do it and puts less strain on the drive train.Desert, I think we're talking about pressing the brake and the accelerator at the same time, thus manually applying the brakes to limit wheelspin. And by applying the brakes, you automatically override the traction control. So, if the OP is talking something else then I could be way off base.
Note to everyone: notice I didn't touch the topics of effectiveness, or how the technology gets applied, or any of that stuff. I just said "Yeah, brake and gas at the same time".![]()
