Extended Warranty Expiring Soon
Panzer07
Ontario, CA
As the tittle states it...my 2 year extended warranty will expire on May...and I wanted to ask you guys, which I'm sure have a hell lot more knowledge than me, on things I should be looking and inspecting on my H3, and hopefully have them covered and replaced within the warranty.
Panzer it is an 07 with 88,773 miles in her...major certified repair she has had replaced was the radiator and all the hoses, as well some transmission sensor, and the cruise control thingy (the whole control stick on the left side of the steering wheeling).
any thought of what I should be looking out for, for a truck of my year and mileage ?
So far I haven't encounter any major problem, except a leaking cv boot (I think that's what it is call, as well I do have noticed the boots from what i believe are called tie-rods look pretty crack. basically some of the rubber parts down the front truck tires component here I'll included some pics.
Leaking boot (passenger side)
Nothing leaking on this side but look pretty worn out and cracky
Thank you in advance...and I will really really appreciate any info you guys can provide me with...
I would get as much replaced as you can. halfshafts, steering rack if its leaking, upper control arms especially if the rubber on the frame side is starting to go...etc.
Panzer07
Ontario, CA
Yeah those are my exact thoughts...that way I can save some money...Is there a way to check for some I the things u mention (besides the obvious leaking) I don't mind taking pieces apart but what good does that do if idk what I'm checking.
Because I'm guessing they won't changes unless is broken lol
Panzer07
Ontario, CA
Alright Guys Once Again Bringing Back My Old Thread I Finally got a 2 Days Off From School and Spare Time To Really get Down Under my truck and inspect and record all thing and sounds that seem and sound out of sync....
So far I recorded My rucks in all her 3 settings: 4Lo-Lock, 4 Hi-Lock And 4 Hi...Could You Guy Take A Look And Let Me Know If Each Setting in each of the video seem to b working correctly.
4 LO-Lock
[video=youtube_share;mg8AwRtIC8o]http://youtu.be/mg8AwRtIC8o[/video]
4 Hi-Lock
[video=youtube_share;flje98I4XgA]http://youtu.be/flje98I4XgA[/video]
4 Hi-Unlock
[video=youtube_share;J8Zdnb-jt-U]http://youtu.be/J8Zdnb-jt-U[/video]
I Fond that the "Metal Scratchy Sound" Is Due To This Piece Of Lumen Sheet Rubbing Against What I Believe It Is Some Sort Of Heat Shield For The Gas Tank.
