- Scottsdale
New exhaust manifold, bolts, gasket, exhaust pipe gasket and O2 sensors
New motor mount, old one was tore up!
Reshaped rear bumper to accommodate 35s
Rebuilt leafs - new bushings (x6), new full length leaf, re-arched
With new shocks too
New u-bolts and hardware, existing tomp lo-pro mounts with new paint. (Still need to cut the bolts)
Reshaped and painted gas tank skid
Also in there: crankshaft seal and bolt, new antifreeze (pulled radiator for crankshaft seal), oil change, TPMS reset (horn beeping method), new rear diff breather tube, moved rear ABS line mounts 1.5" lower.
And a new look. Sitting 3" higher in the rear (1" from tires, 2" from springs) and 1.5" front (1" tires, .5" as torsion bars keep moving down, likely due to Firestone).
Again, many thanks to Reloader for all of his hard work, and to Jeri for lending me Reloader, watching Parker and feeding me.
With new shocks too
