Cortinas316
- san antonio tx
I just addressed this issue on my H3. My rear bumper was bent upwards a bit in the center, as you can see in this picture taken from under the truck, looking out through the bumper opening. We flattened that section with a block of wood and a sledgehammer. The tire was also hitting the ladder so we added 3/8" spacers between the mount and the door to push the tire out.
You don't need a lot of extra room so I don't know if I'd go as extreme as that mount that you found.
Here it is bent down (overcompensated a bit with the bending) and now the tire fits. It touches the plastic but not with any real resistance and the door closes properly.
The extender would probably put more stress because of the added length on the door and door mount creating a bigger problem to an already weak feature of our rigs than simply bending the bumper..... Keep things stock where you can, saves you lots of hassle.
I should have worded that better. The door hinge is the weak part
We looked at this option too but there isn't much room to play. You can't really drill all new holes though you could enlarge the current holes. But then it wouldn't be as strong, or might be prone to sliding down over time.You can remove mount from the door and move the studs up a bit. I remember seeing someone did this years ago but I have been unable to find it. Also, a body lift would fix the issue.
