switch location
I ran a wire from the switched 12v wire behind the radio. That turns the leds in the switches on when I turn the key on. I also ran a 12v to each switch from the aux fuse block. Then from the switch back to the relays... The switch also has an led that lights up when the switch is in the on position...
Blake-O
Maryland
this is where i mounted mine
[/URL]
[/URL][/IMG]
[/IMG]
Like the location of your switches. Do we have to remove the seats to get the center console out?? Thanks.
What year of center consol is that from?
I have a small pocket in that location... thought about cutting it out for switches, but wasn't sure if the size of the switches would match up well or not
benlaud87
Maryland
I have a little pocket there as well. I like the look of switches there much more than I like a little coin tray that just collect dust and garbage
You could get a switch plate that was big enough to cover it or fab up something yourself....kinda what I plan on doing when I overhaul my lighting system (swith to leds)
Ed's06h3
Haledon, NJ
Blake-o no you don't have to remove your seats. You just have to remove a screw (on shifter knob with a Allen key) and it just pops off very easily.
Ed's06h3
Haledon, NJ
I think it's from an 06 & 07 I'm not sure what year they started adding the coin pocket..
Chocflip201
In the Rocky Mountains
Utah
I didn't have any screws to remove to pull my center console. On the leather shift boot around the gear selector if you pull the edges in towards the shift lever they will come undone, then you can tuck the leather in through the hole and lift up on the center console (by first lifting at the gear selector hole edge) and the quick clips will release.
Here are my switches.
Blake-O
Maryland
My center console is coin tray free -- 06' Luxury. Can't wait!!! Just ordered my switches.
954paulo
ny
Did these a few years ago. If I could find another oem plastic trim piece I would redo them tho
954paulo
ny
Yup I installed heated seats when I changes them over to leather
Blake-O
Maryland
Yeah.. I really like my leather seats. No way I would own them without heat. Had a VW like that once, didn't care for seats without heat.
Chocflip201
Utah
Does anyone have any links or leads to push-button switches that will look good where the factory "blanks" are in those two round spots where the factory grille and roof light switch buttons are supposed to be? I've been inactively looking, and haven't found anything I love.
