Will these rims work???
Hayden
Toyo M/T
Virginia, US
No, if you look in the description theyre 5 lug. I know the picture shows 6 but the lug pattern wont work haha
But as far as offset it would
Hayden
Toyo M/T
Virginia, US
Yeah they should they will, without a doubt, stick out from the truck more because of the offset but if thats what you want its all good. Can anyone else confirm this too? I dont wanna be the only one
Also, what tires are you running?
-6 offset? If hes gona run 35s then I highly doubt it. My friend is running +2 offset on 35s + 1" bodylift and barely clears the rear part of the front fenders! I ran +10 mm and probably had a 2 mm gap before the bodylift (just saying)
poweraidon
georgia
I'm gonna run some 35s. I like the wheels sticking out look. So will these fit with 35s? Will I still be able to off road? Or is rubbing gonna be a serious issue
Those will work for 17" tires though. The first ones u posted are for 16s.
They will stick out 23 mm over stock wheels (if you keep same tires suposedly). The wheel is also an inch wider than stock. Personally I like really wide wheels, they make the tires you put look wider... 35s on 16x10 wheels look boss!
poweraidon
georgia
I'm gonna get those with kumho road venture mt tires 35x12.5r17. So everything should work and there wouldn't be any rubbing right?
Ull get very minor rubbing on ur sway bar at full lock but its normal and doesnt do any sort of damage whatsoever. Ppl that run 35s on stock wheels get more rubbing and its not an issue. You may need to check the backspacing on that wheel to see if it clears ur brake calipers though.
