I got a 10.2:1 462 big block sitting in my shop. I bet that would wake things up!
CaseyS......do u have a build thread on your cummins conversion?
I vote 5.3 too. It seems the easiest. 4bt's issue I see is wiring not the fab. Wiring seems intense...
I gave up the supercharger idea on the I5 when I got quoted 5k JUST for the supercharger, no injectors, no inter cooler, nothing else. **** that! I would be in 7k when I'm done or buy a 5.3 from the yard for 2k or less. it can fit just not sure what wiring will go on
The 07 has it's own PCM different from the 06 and the 08 on up, which came with a TCM as well as the PCM. The 07 actually has the most free memory of all the PCM's.GM bored out the 3.5 to 3.7 for the 07. And I've been told the computer software didn't change.
There are others here better than me at this. They can help you determine if you just need a new head out a complete rebuild.
From vehicle history. My vote Is you most likely need just a new head.
Sent from my MB886 using Tapatalk
Yeh thats crazy. turbo actually wouldnt be so expensive and relatively easy as long as you can weld your own manifold/downpipe. 60lb injectors and replace the the pump in the tank with a 255 walbro. Find someone to tune it and your good to go.
Hmmm....Any good threads? A turbo wouldnt help much offroad but I dont need any more power for wheeling, thats what low range is for. Its the street that kills me, I live in a hilly area and any road trip I am constantly climbing up and down hills and 65-70 mph with a heavy fully loaded H3.
Supercharger is out for me. too pricey
4bt is out for me, its badass but its too over the top for me.
5.3 I dont mind fabbing crap up for the swap its just electronics worry me
Turbo, I like that idea seeing its cheaper then a swap and supercharger, my only concern is engine longevity. Smog I can deal with...not worried about that. I know nugget HATED his turbo because turbonetics ****ed some things up but I would avoid them.
I would think the 5.3 would be the easiest swap. The 4bt is an interesting choice but damn those things are loud.
there are few turbo builds over on 355nation but i dont think anyone has attempted it on our h3s
Remember to shoe horn the 5.3 in the H3 they flared the front frame and moved the firewall back some, or so I heard from a reliable source. lol
Might want to do some serious measuring on that.
The 4bt is about the loudest diesel motor I have been around.
No. Nor do I want to. I have not had the chance to tune anything yet, but smoke is not acceptable to me once I reach a final tune. It does make a little puff right on startup though.Not to thread hijack too much...but Casey, can you blow black smoke out of the 3??
