How do I get an iPod input to work?
S
SedonaBound
The new T has an iPod connector plug hard wired into the Monsoon/XM/6-disk changer head. I can't figure out how to get it to work. With the head on and iPod on...it just continues to play the radio. I tried all the bands, nothiong recognized the iPod. The iPod connector has "Peripheral" brand molded in.
Where's the iPod cable coming from - under the dash? Maybe it's an iSimple unit. To access the iSimple options, you click through with the Band button until you get to XM1 and then you use the Tuning knob to scroll through the choices. I believe there are four choices - Aux1 is Sat, Aux2 is iPod, Aux3 is 3.5mm jack (if equipped), Aux4 is unused, if there's even an Aux4.
If it's not the iSimple, I dunno. But pics might help.
S
SedonaBound
That did the trick; thanks. Went to XM band, and then found an iPod setting via the tuner. The connector is led through the console storage.
