Offroad Evolution SAS H3T Alpha on sale
ReconH3
Guardian Angel
Raleigh, NC
Offroad Evolution is selling their SAS H3T Alpha at $41K. It has 36K miles. The SAS was done after mine so it has some improvements and is also a ProRock 60. If I had the money, I'd be all over this. Hope it finds a good home.
ReconH3
Guardian Angel
Raleigh, NC
Serge let it go a long time ago. It's been ORE property for some time. Sometimes I wonder why Serge even built it if he got rid of it without really using it.
"Ex Umbris Venimus"
Panzer07
Ontario, CA
That's a badass truck I was lucky to see it and wheel alone side for my first time out with the H4O guys.
Torres
"Ex Umbris Venimus"
Serge didnt have that rig built. He never owned it. It was owned by a guy that is referred to as "Mr. G" on facebook by Mel. He has a ton of different rigs. He then sold it to mel and serge bought chase 12 when Mel bought the H3T to replace chase 12
Mb30sdl
Hamster that pokes Bears
Raleigh area NC
That truck needs atlas TC and probably some other stuff. Plus I talked to Drew ~a week ago and he didn't mension T for sale. But I think I have something else in mind.
Mb30sdl
Raleigh area NC
Without Atlas u need to be in 4Hi locked to run 2wd ish( front driveshaft will rotate?) or unlocked with hubs engaged.
What about 4hi lock with the hubs disconnected, wouldn't that give you rear wheel drive?
owlxxx
Tehachapi, CA
how many H3 SAS's has ORE done? it seems like at this point they should just make a kit.
IDK maybe 3? A kit would be nice but there has to be alot of fabrication that goes into it. Not many people are gonna wanna cut and weld. As others in this forum have shown, you can do it yourself alot cheaper than what i believe ORE would do it for. you just have to be brave enough to take that first cut. If it was a bolt on type thing with minimal cutting and grinding then I could see a kit being available. But the market for H3's just is not there in my opinion. There is probably a different JK in his shop every week. A handful of H3s probably aint worth the effort to develop a kit.
They have done 2 Recon and the H3T.
The only luck you will get in getting a kit is through CJ. While you might not have a prorock dana 60 you can get a dana 44 for a ton less money and keep the ABS. ORE makes cool stuff but almost everything that gets done in that shop you come out with 15k less in your pocket minimum. Most people cant afford it. See his facebook pics, a lot of those JK builds have more money in shocks then I do or 95% of all wheeling JKs in someone whole setup. Looking at the H3 ABS hubs I bet you could even adapt his tone rings to a dana 60 hub by turning down the O.D. of the hub or I.D. of tone ring itself and press them on to the hubs. Then you just need adapter brackets for the H3 brakes and H3 sensor mount
As for interest DIY kits would not make ORE much money. I would say out of the half a million H3s built you have only a few thousand that probably wheel them religiously (as in not one or 2 times) Of those few thousand only 7 are SAS. Theres not much money to be made for a big company. I have hope though, I think I was #7 for spring over H3(T)s and now we are probably nearing 15. Owners are slowly getting out the torches and welders or paying someone to do it which is good! Your almost on your own with an H3 but companies like ruff stuff, ballistic fab, parts mike, thorparts, you can piece together your own stuff.
