gotta get a extrenal trans cooler before last chance canyon trip!
I used the derale 16503 I think. Not positive on those numbers but it's been working good. Added a thermal bypass to the system too. 06H3 used a 160 degree bypass. Mines 180.... The 160s I found were quite a bit more expensive...
Poncho and I are running the same one. Do you plan on completely bypassing the OEM system or integrate it with the stock one? Do you plan to use run a thermostat?
Also do you have a scan gauge to monitor the temps?
JonBishop
Glendora, CA
I plan on completely getting away from the radiator tank and running the cooler, not really looking to much into a thermostat, and I do plan on getting a scan gauge in the next couple weeks [emoji4]
Yeah.... What they said. I'd agree with going bigger. You could always stack another one on top of the first one and double it up. I might do that next summer. I dunno if I have room to go with a larger single unit, unless larger just meant thicker.
my install is ghetto too and the SAS made it worse, now there is nothing for me to hang it off of. I gotta pull the bumper and figure something out. It does work though, I am running MUCH cooler then I ever was.
JonBishop
Glendora, CA
Came in the mail today[emoji4] now just waiting to get my new thermostat seeing that mine is leaking [emoji35] and all is good [emoji4]
