As some of u know I tore into my Alpha a few weekends ago. I replaced the uppers, CV's, and both axle seals. I also drained and put new 75/90w in the front diff. I drove it maybe 50 miles and I had zero leaks or seeps. Today after getting home from work I crawled under it to check something and the LF seal had a little splatter on the diff mount. Checked the other side and it wasn't as bad. Wiped em off and went for a short trip. They both had a small layer of 75/90 all around the lip of the axle seals.... Is this a common thing until the new CV/seal wear in??? I know the old CV's had basically a grove worn into them where the seals were. I'm going to keep an eye on them, but could the cold weather be at fault??? I made sure the diff wasn't overfilled and it was fine. If they need replaced already they're just gonna seep a while lol.
