I work for a trucking company and had one of the diesel mechanics in the shop do my front brakes and rotors recently. Usually I would do this myself but I work so much I decided to pay someone. We'll everything was fine for about a month then I started hearing a grinding noise in the front , sounded like metal grinding, almost like scrubbing rotors. We'll after two weeks it finally got super loud so I jacked the front end up and shook the tire and found a good bit of up and down play. I'm guessing its a bad wheel bearing. I decided to go ahead and pull the wheel off to check it out and found the rotor didn't seem to be bolted to anything. I shot a youtube video you can see here
http://youtu.be/piubZ4XTCSU
i immediately stopped driving it. What happened? Shouldn't the rotor be secured? Is there a wheel bearing DIY or do I Need to do the whole hub assembly? What's the best place to get a hub assembly?
