Dead Battery Again
H
H3Ray
Geez! I am so annoyed right now. Got home tonight after 4 day get away and the H3 is dead. Battery is dead. Now I have call a tow truck again, and back to the Dealer demanding they fix it right. Is the 2009 Alpha H3 a lemon? I am so annoyed right now.
:roll: :roll: :roll: :roll:
Is it the original battery? If so 5 years for a battery, that's an average life if not more then average. definitely a lemon
5 years on a battery is pretty good. Plus its colder weather now, now is the time for a weak battery to die usually!
Best4x4
Vidor, TX
Yeah if it's the OEM battery it did good to make it that long. I'd just grab a new battery and call it a day!
I've been killing the battery in my 08 Alpha... it could be the battery, but it's less than a year old, what I'm thinking the problem is is similar to a problem I had with a 06 GTO - the computer wouldn't shut off when the ignition switch was turned off. The Alphas, in GM's thought pattern, turn on the computer when you put the key in the ignition. The problem is, if you turn to accessory, the computer stays on for 30 minutes (why, I don't know, I just know this is how it's programmed). Sometimes it doesn't shut off, and eventually just stays on 24/7. It will make your battery dead enough that it won't start after 24 hours. When the GM tech looks at it, make certain he checks for this issue - they HATE checking this stuff because it doesn't pay squat for the amount of work it requires; but perhaps if you get him travelling down the path, it will quickly turn out to be a computer (yep, you have to replace it)....
Don't leave your key in the ignition, and if you're having to pay to fix, pull the relay (71, IIRC) when you shut the car off - then when you go back after 3 days, plug the relay back in - if it starts... there's the issue....
New Jersey
If its the battery, I woudo replace it with a dry cell battery, as they can withstand the cold weather a lot better during cranking, and if it's the computer or so, like SuperBuickGuy said, it might be cheaper to get an emergency vehicle unit called a "charge guard" it's an unit connected between the positive cable and the battery, that once connected, if it detects any abnormal current draw, it will shut down/disconnect the battery from any further loss of charge. The unit will activate the battery I mediated upon turning your key in the ignition. It's very useful, and a great preventive measure, which is why it's in most emergency vehicles.
