Replace Thermostat in 2006 H3
jjjerry23
Memphis, TN
Check engine light pop on, got it check at autozone bad thermostat. Looking to replace it myself. Do anyone have a diagram, steps, or any helpful information about replacing the thermostat on my 06 hummer h3?
Thanks
taylorblake831
western washington
Yea mine turned on for that like 6k ago but it said stuck open and mine hardly ever moves above the 1/4 mark on the dash so I never really bothered to fix it but it is a little annoying and will probably end up fixing it in the near future because if it sticks open it will most likely stick closed when I'm on a trail somewhere knowing my luck
-TEXAS FOREVER-
If it's stuck open, it won't allow the engine to fully warm up. if its a cool morning and it doesn't warm up in a certain amount of time, it will throw a code. Around half or even a tad above half on the temp gauge is normal. 1/4 is too low. I pulled the drivers side inner fender liner to get to the t-stat. It took some extensions and swivels to get to the two bolts but changing it out is pretty self explanatory.
desertH3 had a good write up, I think. Search for thermostat and his name, I think you'll find it. From what I call, it's pulling the fender liner, scraping a few knuckles. Extensions and wobbles will help.
scoreh3
It's an easy fix . You will spend more time taking the wheel and inner fender off than you will swapping out the thermostat . Oh and the skinned knuckles part , yes that will happen on this repair . The price of a bandaid vs the price of a mechanic is well worth it .
I had my girlfriend hold a bucket below the lower radiator hose to catch the coolant. Well... She caught it alright. All over the front of her. Lol. I think it was just my truck marking it's territory... Lol
