rsm688
- mississippi
Okay guys I have noticed that I have a little slack in my driveline it seems. When slowing down/braking and then giving it gas again sometimes I feel a little clunk, almost as if there was a little slack in the driveline and when I put it back under load with the throttle it has to catch back up. I thought bad U-joint at first but they all seem fine. So my next thoughts is transfer case or axles. My transfer case was inspected by a transmission shop 3000 miles ago when the shift fork was replaced and they said everything looked fine in there. Could worn gears in an axle cause some clunking like this? I also wasn't sure if the load distribution in 4 hi with the power split betweeen the front and rear might be related to it as well.
Any help would be greatly appreciated.
Thanks,
Spencer
Thanks,
Spencer
