I have had my h3 now for a few months and I have noticed that when first started and driven a few blocks when stopping, there is a a hard downshift to 1st, after a few stops it seems to go away. Anybody else had this problem? or is it a problem at all? I know that the transmissions tend to be an issue on the H3 after about 100k miles. Mine is at 97k. Any opinions on whats going on?
Get some new ATF (automatic transmission fluid in there) and see how it does. I just dumped and filled 5 fresh quarts in and was amazed at how much smoother she is shifting now. I did it similar to the way that the guy at this link did:
http://www.hummerforums.com/forum/hummer-h3-17/changed-transmission-fluid-18967/
I didn't drop the pan, I just let 5 quarts pump out from where the transmission fluid lines connect into the radiator (everything is stock on mine, I don't have the cooler like the guy in the link did). But I was familiar with the transmission lines because I had just replaced the radiator. And while I didn't change out the atf filter, from what I understand, most dealerships just vacuum out from the top and replace, so they aren't changing the filter either.
So... to do it my way:
1- remove front skid plate
2- get a big open drain pan and mark lines at where 5 quarts fills up to (pour that much water in the pan and then scratch in marks at this level)
3- remove the clip from the drivers side transmission fluid line where it connects to the bottom of the radiator
4- open the atf filler cap in engine compartment
5- have someone start the truck until 5 quarts are pumped/leaked out (check to make sure no coolant is mixed in)
6- kill truck
7- put 5 quarts of new atf in (I used dexron VI)
8- follow user manual for checking atf level
9- repeat if you want to flush out even more old fluid (the system holds 11 quarts total)
