ReconH3
Guardian Angel
- Raleigh, NC
I got two crazy ideas that came to mind when I was working in my truck.
First is real simple and it takes like 30 seconds to implement and is reversible. Simply remove the rubber seal at the end of the engine bay. The one closest to windshield that seals hood when closed. I remember seeing hot rods with spacers to do just that. This could be a quick fix if your out on the trail, but still a long way from civilization, and your having overheating issues.
Second requires some PC fans and either a temp switch or a manual switch. You would install them inside the faux intake covers. Depending on how much air you want to move, you would enlarge the portion that lies in the engine bay. This wouldn't make a huge difference, but if you combine it with a working hood vent, it could be enough to keep temps from going up. I'm going to look at this possibility and see what I come out with.
"Ex Umbris Venimus"
"Ex Umbris Venimus"
