A word of warning, though, their instructions have the wrong torque spec for the bearing caps - it's way high.
True! The H3 front axle gearset is robbed from a earlier, full-width, rear axle. Most of the rotating parts are the same, including the ring & pinion but, the IFS housing is much more "dainty" than the full-width rear-drive version. My guess is that Yukon robbed the torque specs from the original rear 7.625, not realizing there are different torque specs for the IFS housing. So don't try to torque the AAM-7.625 IFS main caps to 65 ft/lbs. (especially on the alum. version). Many axle guys have little experience the IFS version (or even know it exists)...so make sure you are using IFS info and not the 70s-80s rear axle info.
This same gearset (and differential) was installed in many 70s-80s era rear axles (Malibus, Camaros, S-10s, etc.)....so you can get gears, bearings, and diff parts from almost anywhere. But there are some items special to the IFS version, and a lot guys have a hard time finding them. You can get the gearset from any source...Yukon, USA-Gear, Richmond etc. But NOTE: Most aftermarket gearsets will be 5-cut and they require more lash than the factory 2-cut. Make sure your set-up guy is aware of this. If he sets the backlash from the GM manual, using aftermarket gears...it will be too tight. To my knowledge...GM (AAM) is the only source that is making 2-cut gearsets for the 7.625.
I have found the best source for IFS parts is directly from AAM. They offer several sub-assembly "kits" for whatever part of the differential you need to repair. Fantastic quality....much nicer than Yukon.
http://www.demandaam.com/axle-results?vm=GM&q=7.6"+IFS+-+Front+Axle
