when I put the doors back on, will it be difficult to plumb them? or will they go on pretty even already?
They're just like Jeep doors, they just drop into the hole, they're made to come off easily.
I took mine off maybe 40-60 times, and never had help, the front doors are heavy, but ti all comes down to holding the door in a way so you can see the hinge easily to put it back in smoothly.
the connector for electronics is a handle that you pull out & down to get it to release... real easy. After the first time, I only re-attached the friction thing, not the hinge bolts (just like most jeep guys don't put the torx bolt back in the hinge after first use)... the 80 lb door is NOT going to just fly off, and the bolts fit nicely in a plastic bag in the glove compartment!!
Btw, once you've done it once, next time it's about a minute a door max, I use a small impact with the 10mm you need on it... super easy.
