Synthetickiller
- United States
I bought an 09' H2 with about 106k miles.
I don't know the previous owner's history, but I'm finding out very quickly he trashed the suspension & moved onto something else. Everything I've removed has been beat to hell. I figured I'd save money doing the upgrades myself & use the saved cash to put towards a diesel eventually. That's why I'm looking at upgraded parts. We don't rock climb here or run anything like the Baja. Everything here is mud, mud & more mud. I don't know if that'll effect what parts I should get, but that's why I'm asking. I'm running 35s, but would only upgrade to 37s, no lift.
So far, I've installed King shocks all around, Front & Rear Helwig anti-sway bar w/ new endlinks, bumpstops, rear axle tie rod & upper and lower rear control arms, scorpworx differential crossmember, new breaks & rotors, plus new wheels & tires. Everything I've listed below is what I think is left, minus an alignment.
I've spoken to a few people (Big2dabank & Scarsman, thanks guys!) on here about what to buy & also called the Dmax store. Unfortunately, Dmax couldn't recommend much to me other than one or two tid bits of info. So, I'm back here, looking for a consensus on what's good & what's not...
Front suspension.
I know I need replace the upper & lower control arms.
1.Uppers: Kryptonite UCAs (Should I save money with the Dmax XDs?)
2. Lowers: Kryptonite LCAs (Can anyone confirm that these fit?)
3. Keys: Mine are really rusted. Should I replace?
4. Torsion bars: no idea of these are bad.
Steering.
Everything seems to be shot.
5. Tie Rods: DMAX XD Tie Rods ($110 cheaper than Kryptonite & more heavy duty)
6. Idler Arm: Kryptonite death Grip ($300) vs Moog Idler/Pitman Arm pack ($190). (Is the Kryptonite worth the price & cutting the frame?)
7. Pitman Arm: Moog vs Moog XD (I don't see other choices, probably would go XD if it is overbuilt for only $30)
8. Pisk: heard it doesn't fit.
9. Centerlink: Been told by everyone this isn't necessary
10. Maybe look at the Dmaxstore Ultimate front en package stage 2 w/ appropriate options?
11. Anything else?
If you come this far through that wall of text, thank you! Any help would be appreciated.
Front suspension.
Steering.
11. Anything else?
