Synthetickiller
- United States
If you park with your wheels turned almost full right, you can see if you rub the bar. Some do from the factory, some don't. Mine did only on the passenger side, slightly, with the military 37's i rub a tiny bit on full lock on the inner fender. I've replaced everything except for the pitman/idler, UCA & LCA. I debated aftermarket vs GM, and its hit and miss. I'm guessing it largely depends on the install, and the attention paid during the process & alignment. I'm following this thread with great interest.
Keep in mind that I'm not as knowledgeable as most in this thread. The blind is leading the near sighted.
Whenever the weather lets up, I'll go see if there's any rub with my 35s. I'll post some pics to see where everything is right now. I should be able to in a week when the rain lets up.
The stock wheels on the 09s were 20s (I have never seen one with OEM 17s). They had an offset of 18mm & I'll assume the backspacing is the same as the 17s, 5.5". The Ultra Colossus 17s I'm running are 12mm offset, 5.472", but are 9" wide vs 8.5" with the stock. I guess they work out to be about equal. I just don't know if that effects on rub. Only mentioning that as just something to consider. I'm probably overthinking it, honestly.
