Possible transfer case issue........
ffmf2101
London, Ky
Hey guys ...... One of my buddies was having some issues with his 07 H3. Couldn't get it to switch to 4 hi or low lock at all. Long story short I fount his sunroof drains stopped up, as well as wet connectors. Got everything cleaned and dried and now it's shifting into lock and back to awd fine.
New problem..........
Shifting from 4 hi lock to AWD it doesn't switch instantly..... It waits until a mile or so down the Rd at 50 mph is switches back to AWD with a noticeable jerk which feels like it's coming from the back end but not real sure. I tried searching and couldn't find anything on the forum like this. Any help would be greatly appreciated.
ffmf2101
London, Ky
Ok since I am decently mechanically inclined, is that something I can pull the case out and apart, as well as check and replace myself?
Yes, but replace the OEM plastic fork with the aluminum aftermarket one made by Dorman. A search on the forum should locate the part # for you.
ffmf2101
London, Ky
Yeah I was gonna say after I asked that question I just found some threads on it. Thank you guys.
OEM replacement fork is aluminum, they did away with the plastic one
Has anybody replaced there chain while they were replacing the shift fork. and where did you get the chain from.
run away from that one, the chain is (last time I checked) nearly $600.00. I have a broken chain and broken couple of gears in a t-case I replaced.... it really was cheaper to source another t-case (a 4:1 case)... I keep waiting for someone to break a case, should that happen, I'll piece this one back together....
about knocking the case apart, I have a transmission guy that still cusses about having to take the adventure case apart.... do get the instructions (as he eventually had to do). It's not a NP203, 208 or 241...
Wait a sec....shouldn't you not be driving at 50 mph while shifting the t-case? I know you can be moving when shifting between 4 hi and 4 hi lock....but 50 seems to be pushing it. Atleast that's what I recall that she manual saying (could be wrong tho)
I can get you any t-case parts you need. Chains run $230.
All GM forks I have found were plastic. I use the Dorman aluminum fork for this reason. If someone knows of the GM part number for an alum. fork...post it up.
CaseyS
Louisiana
I recall it won't change modes above 45 mph. Try it again at 40 mph and see if you get different results. Consult the owners manual, the lockout speed is listed in there somewhere.
ffmf2101
London, Ky
The mode button was pressed before takeoff... The mode changed on its own around 50 mph
GM does make an OEM aluminum shift fork. Part no. is GM # 19180438
http://www.amazon.com/General-Motors-FORK-19180438/dp/B008Y9248U
