P0140 / P2A01 DTC codes O2 sensor issues
Azjohn
I got the check engine light for P0140 and changed out the o2 sensor like it listed (Bank 1 sensor 2 post CAT) with an ACDELCO OEM 213-3908 . Cleaned the codes and the error returned. Checking the ODBII readings for the O2 sensors (I didn't realize i could do this before I changed it out) I'm getting a voltage of 0.0V to 0.8V for sensor 1 and a solid 0.4V for sensor 2. What should the voltage be, and also any other ideas on what the issue could be to through the P0140/P2A01 codes?
Thanks!!
Sorry, don't know the voltages. Have heard a bad, new in box sensor being an issue. No exhaust manifold leak or something like that, is there? (Fishing for possibilities)
Sent from my SM-N920V using Tapatalk
Azjohn
I can get you the voltages and more info on the codes on Monday. I don't have access to all data at home
that would be very helpful thanks. I'm going to dig around more today to see if i can find something else. Maybe try another sensor as well.
