diggersh3
- Northern Michigan
I am looking for any ideas on the issue I am having with my H3.
I have a 2006 H3 and the blower motor quit. It is not any of the usual suspects. I have checked all the fuses. The relays. The wiring and so on. I have replace the main heater control switch, the resistor (no burning), the high speed blower relay, tested the blower motor on a bench, and checked the continuity through the blower resistor harness with my DVOM.
I have power at the main harness for the resistor - blower - relay wiring harness connector hooks up. I have power at one terminal on the resistor plug in and power going to the motor plug. When I plug in the motor i get power through both connections back to the high speed blower relay. If I plug in the relay I loose all power.
Any ideas of what I am missing or the possible issue?
