Fog lights switch
marko.kessler
I replaced my fogs with LED's. Any way I can convert fog switch to come on at high beams only instead of low beams only?
Marko
Sent from my SM-N910W8 using Tapatalk
rsc
Tulsa
I know you can wire them to come on with BOTH hi and low beams, can't remember if you can do just hi beams. I'll have to look around for the wiring diagram I saved. You can google "H3 forum fog lights on high beam mod" and find plenty of info on doing it.
Yes. But you need to tap into the ground side of the headlamps since the BCM controls the hi/lo beams via a ground through a HI/LO relay. (But might want to check local laws too if using this setup on highways.)
HEADLAMPS
H3%20headlamps_zpsgzi6ljxz.jpg~original
FOGLAMPS
H3%20Foglamps_zpsfvu3dnia.jpg~original
Odimus
Maine
any reason for this mod to have the fogs on only when the high beams are on? There may be times when you need the fog lights but the high beams will be too bright...
marko.kessler
I removed fog lights and replaced them with LED's and added light bar. Legally here I have to run LED's off high beams only and has to have a switch.
