electrical systems....sucking :(
So i have noticed that everytime i hit the window up or down button, the tail lights, head lights and interior button lights all dim. Is this a normal thing, or do i have an electrical issue of some kind that i need to get fixed?
I dont have any accessories that are draining electrical juice, i have 6 off road lights, but those are almost always off. Any info will help thanks!
kd7irm
Regular Guy
Bagdad, Az
I have the same issue, have replaced the battery and that fixed it for a while but its back now and if I roll up or down windows or have the dome lights on after the key is off the next time I try to start it, its dead.
05Mudiak
Lake Charles, LA
ok so it does it with any individual window is lowered or raised, next question does it do it with any switch or just the drivers switches?
M22KLARS
Unsafe At Any Speed
Minnesota
Have either of you upgraded your battery terminals? Or checked for a loose connection? Maybe your Alt is on it's way out... Any other weird electrical stuff?
kd7irm
Regular Guy
Bagdad, Az
I haven't upgraded the terminals but have checked them and for loose connections. I have noticed that my scanguageII reads high voltage, like around 14.9. With the new battery at first it was like 12.9 volts. Alt checks ok. No codes ever.
