H3 Cai?
JonBishop
Glendora, CA
an have no problem with it an love it but jus wondering if theres anything better you are all using
His name on here is Doc olds and you will see his advertisement up on the top of the screen every now and then
M22KLARS
Unsafe At Any Speed
Minnesota
AirDoc is the best! K&N is good but it leaves your filter exposed to the elements (water/sand/dust) where as the Airdoc keeps your stock box but removes the restricting parts of the OE set up.
I used to run a K&N and switched to an AirDoc. For me I wanted the seal up my filter for any potential water crossings and after I switched I noticed that my engine seemed to run smoother and the air temps in the intake stayed within 10 degrees of the ambient air (when moving) where as my K&N temps would run all over the place.
cbetts
NERD!!!
Rancho Palos Verdes, CA
Most of us run an AirDoc with the stock airbox. We get the benefit of a more air and a cleaner place to pull air in. I run a K&N on the road but run a paper filter when wheeling. I found the K&N got too much dust caked on it with the dusty trails here in SoCal.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
For the offroad use our rigs see, I would suggest that retains the factory air box like the Air Doc or GM Performance kit (only available for 06-07's).
Seeing a link for the air doc has already been posted, here is a link to the GM Performance one
http://www.gmaccessorieszone.com/Hummer/en-US/H3/Performance/Performance%2bAir%2bIntake/2006
One I found on eBay for a good price
http://www.ebay.com/itm/17802464-NOS-GM-Air-Intake-Hummer-H3-Chevrolet-Colorado-GMC-Canyon-/280770543581?hash=item415f3a7fdd&item=280770543581&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr#ht_500wt_1413
all you need is a can of Rustoleum spray on bed liner to de-bling it a little :wink:
Another option is making your own using the factory air box. Seeing you have a 06, you will want to modify the factory air box snorkel inlet with something a little bigger, a silicone reducer will work for this and is included in the Air Doc kit.
Flash
Michigan
unless you like something shiny under your hood...:thumbs:
