I'll have the body lift on this weekend (with the break in the rain, maybe even tonight?). I have no rubbing in normal driving at the moment aside from a small amount of rub in reverse at 3/4 lock to the right, none anywhere else. I am looking at steering rack upgrades like the Mayhem kit or the Outfitter Design kit to remove the slop in the steering so I don't brake a rack. The tires are just as wide as a 35, but a little heavier so it will eventually need to be done. If your crossmember bushing is worn, now would be a good time to replace that too so the front doesn't move around and stress the differential housing and gears.
