Vdawg1115
- Oakland, CA
So yesterday Was the first time I serviced my H3 since I got it. About 3,000 miles ago. I changed the oil to Mobil1 synthetic and the T-case to synthetic Dexron VI per my manual. I also got started on the transmission fluid change. I used the write-up Alrock made a while back as a guide. Everything went fine. Removed the front prop shaft, started unscrewing transmission pan bolts. But there is one bolt I can't get to. There is a bracket not present in other write ups and pictures. It looks like it is holding up an exhaust mount or something, but it connects to the crossmember. I tried unscrewing it but I could only undo one bolt that didn't seem to help much. Then I tried the remove the crossmember and when the TCase started lowering I freaked out and bolted the crossmember right back into place. Not sure how to remove that last bolt.
Should also mention mine mine is a 2010 Alpha. Has that flex fuel badge. Not sure if all that makes a difference.
