WTS A ton of stock parts, headlights, radio, trim bezels, wheels & new 33" A/t tires MORE
Jayson DK
Ohio
Contact me if you want any of it!
Factory Polished Center Console / Shifter Bezel:
2006-2010 HUMMER H3 CENTER CONSOLE UPPER SECTION TRIM CUP Holder Shifter Bezel | eBay
Factory Polished Radio bezel (w one small scratch):
2006-2010 HUMMER H3 OEM RADIO TRIM BEZEL FACE PLATE ALUMINUM CHROME A/C VENTS | eBay
Factory transfer case module:
2006-2010 Hummer H3 OEM Transfer Case Module w/ Rear Locking Diff 24236867
Factory OEM Monsoon amplifier:
2006-2010 HUMMER H3 OEM RADIO STEREO AUDIO AMP AMPLIFIER MONSOON SYSTEM 15086821
Factory monsoon rear door speakers:
2x 2006-2010 HUMMER H3 OEM REAR DOOR SPEAKERS 15086827 DELCO TESTED | eBay
Factory Radio:
2006-2010 Gm Hummer H3 H3T OEM Chrome 6 Disc Cd Changer Am/Fm Radio 15261537 | eBay
Factory Monsoon tweeters:
2x 2006-2010 HUMMER H3 OEM Front A-Pillar Tweeters Monsoon TESTED | eBay
Factory OEM heater/ac controls (slight damage to middle button)
2006-2010 HUMMER H3 OEM Heater Temperature A/C Climate Control Contoller Fan | eBay
Factory OEM heater a/c controls with no damage:
Factory programmed speedometer:
06-10 HUMMER H3 INSTRUMENT GAUGE CLUSTER SPEEDOMETER PROGRAMMED TO YOUR MILEAGE | eBay
Factory transfer case 4x4 switch:
2006-2010 HUMMER H3 OEM TRANSFER CASE TRACTION 4X4 CONTROL SWITCH Front Dash | eBay
Factory OEM front side markers:
2006-2010 HUMMER H3 OEM LH&RH SIDE MARKER LIGHTS LAMPS orange Front Fender
NEW aftermarket amber turn signals:
2x 2006-2010 NEW Hummer H3 LH & RH Front Turn Signal Lamps Amber Sealed In Box | eBay
OEM Foggy fog lights:
2006-2010 Hummer H3 Fog Lights OEM LH & RH Foggy | eBay
OEM LH Headlight:
2006-2010 HUMMER H3 FRONT LEFT HEAD LIGHT HEADLIGHT W/ TURN LAMP ASSEMBLY OEM | eBay
OEM RH Headlight:
2006-2010 HUMMER H3 FRONT RIGHT HEAD LIGHT HEADLIGHT W/ TURN LAMP ASSEMBLY OEM | eBay
OEM 16" Wheels w/ excellent condition 33" Bridgestone all terrain tires:
06-10 Hummer H3 4x OEM 16x8.5" Wheels & 33" Bridgestone All Terrain A/T Tires | eBay
Panzer07
Ontario, CA
Pm a price for the front seats back adjusting levers and, 2 tow D-rings and their respective mounts. If these are available
