2006 H3 I-5engine Parts and Aplha V8 bell housing
speedy
Sir Welds a Lot
Dayton NV. Battle Born!!
2006 H3 Built 4L60E. Less then 20k 9clutch 3-4 kit, paper/rubber kit, molded pistons, transgo kit, wide red eagle 2-4 band, beast reaction shell, filter, duralife pump bushing, and the aluminum accum pistons.Includes torq converter with 140k. Used but in good working condition when pulled. 1800.00 B/O would rather not ship. Last one cost 250.00 truck freight and had to be on a pallet.
Complete 2006 H3 air box and tube 145.00 plus shipping.If you need the part that bolts to the engine "top of picture" add another 25.00
No charge for the oil:roll:
Coils,engine wiring harness, ac pump. complete rebuildable long block ran when pulled. low compression in 2cyl sucking oil in to intake.
Anything else attached to the engine just ask.:)
Bell housing-SOLD
H32NV
Golden, CO
Ly6
going to talk to you and bebe about an LY6 conversion in Moab in a week. Will I need this bell housing to do that? If so, bring it and ill buy it.
Thanks,
Rob
H32NV
Golden, CO
I'll have my H3 there with the 5.3 swapped in so you can see it
I have been wanting to see that and talk to you about it as well. My thoughts are if I'm going to the trouble then I'd like to do an LY6 out of a van. 6.0L. The true LS conversion sounds like it has a lot more to it. I think I can find an LY6 engine with lowerish miles (50-80k) and start from there. Would like to keep 4L60e and just rebuild/modify it.
4.8/5.3/6.0 should all be the same work for the most part. Depending on the van and year the only things different would be swapping oil pans/exhaust manifolds and/or converting to drive by wire if it's an older motor.
I hear you on the 6.0 if I wasn't in a pinch with a daily driver down got a sweet deal on an entire car I would have went for a 6.0 or 6.2...but I still love the 5.3 and will take it over the 3.5 any day!
I am looking for a wrecked truck with a 6.0L and a 6L80e.... kill two birds with one stone!
speedy
Sir Welds a Lot
Thanks,
Rob
This is the one you need.It will be in moab for you
EDIT
Looks like we might miss each other. It will be at Neo's We'll settle up somehow
