- Indianapolis, IN
So the power mirrors and dome lights do not work in my H3. I first thought the power mirror switch on the door might be bad so I replaced it, didn't work. After taking the door panel apart I tested the connections and discovered that there is no power going to the power mirror part of the wiring harness, and none going to the motor behind the mirror. The dome lights, I pulled apart the A pillar trim, there is power to the sunroof and the tweeter speaker. However taking actual dome light out, there is no power to that wiring.
To the best of my knowledge the dome lights, hazard lights and power mirrors are all on the same circuit, well the hazard lights still work :huh:. This circuit (if I read the wiring diagram correctly) is on fuse 56, which I checked and it isn't blown.
This leads me to believe that there isn't a bad ground as the other items on the circuit work, and the fuse isn't blown. So now I am thinking there is a chaffed wire or a cut wire somewhere, which I haven't ripped the dash any further apart to investigate/find
Next step is to have someone with a tech II check the BCM to make sure the right voltage is being supplied to the circuit.
If anyone has any ideas as to what the solution may be, they would be greatly appreciated.
