Wrcklsmestiso619
- Houston TX
Hi guys I have a 2006 Hummer H3 adventure package I just purchased for 7,900 with 167,000 miles. I noticed the check engine lightcomes on(p301) randomly and typically happens at idle. The code is p301(cylinder 1 misfire) I replaced the spark plug(oem) and tried a new coil pack and another from the next cylinder and still comes on. Also cleaned the throttle body and maf(idled alot better now) What is weird is I can sometimes drive 100-200 miles with no issues even at idle and then magically the lovely cel comes back on..There are times where the light will come off on it's own other times I reset it with a obd scanner. **My question is should I be concerned? Next question is if I do nothing and continue driving it as is will I have anything to worry about other than a check engine light?** Additionally I tried calling gm about if the head is the original and they weren't able to give me any information. I tried looking for a stamped number on the head but couldn't read the one under the air intake tube(seems to be dot etched) is there another location for head serial number? Thanks!
