jmoffatt
Swamprat
- Shreveport, La.
I made my own CAI for my Alpha for under $70.00, most parts were obtained from here,
http://www.siliconeintakes.com/index.php?osCsid=e347b2ab7041cf
parts were as follows
1' x3.5" aluminum pipe
http://www.siliconeintakes.com/product_info.php?cPath=19&products_id=279&osCsid=e347b2ab7041cf
4" to 3.5" silicone reducer
http://www.siliconeintakes.com/product_info.php?cPath=2&products_id=539&osCsid=e347b2ab7041cf
4"to 3.5" silicone 90 deg reducer
http://www.siliconeintakes.com/product_info.php?cPath=14&products_id=958&osCsid=e347b2ab7041cf
2ea 3.0" t bolt clamps
2ea 4.0" tbolt clamps
http://www.siliconeintakes.com/product_info.php?cPath=1&products_id=310&osCsid=e347b2ab7041cf
and a vacumn adapter kit from autozone which includes the holesaw , grommets and adapters for the cranckcase breather line , and about 8" of 3/8 rubber hose.
I had to cut the aluminum pipe down by about 2" and the 90deg elbow is about 1.75" long on the 4" side I cut that down by .75" for fan clearance measure where you want the breather line drill install grommet and adapter.
The worst part is getting fan clearance I finally had to snip off a 1/4" of the fan tips at a 45deg angle now I have about 3/8" clearance between the fan and the intake.
