Recently, I was prepping my 2007 H3 for undercoat, for a 2007 it is very clean inside and out. It was a New York vehicle, and had been a Michigan vehicle for the last four years. I took out all the wheel well liners, running boards, and skid plates to prep and spray the frame and the floor pans. I was under the passenger side when I noticed a hole in the floor before the footwell goes up towards the firewall. I took the carpet up and there was a lake under the carpet. I have had the sunroof leaking issue that I was able to fix this fall, it was an ongoing battle with the tubes. It seems that the damage was only done on that side (its a small hole), the dealer said it probably went first because of the exhaust under that section. They are going to patch in a new piece, and then I will POR 15 the floor pans and put in new OEM carpet. The carpet is going to set me back $500, I will post the new part number because it was hard to find. The dealer is concerned with the same spot on the drivers side. Wont know if it needs cut out until the carpet and seats are out and its all dried out. The paint and every other area of the floor pans looks fine so far. There is enough water damage to know it was leaking long before I got it in 2013. I only found out it was leaking when I put in weather tech floors mats and saw the water on the mats. So if you have had the leak, I would check under your carpet before its too late, the sound deadening foam holds so much water, I never knew the water was under the carpet. leave it to GM engineers to screw something up as simple as a rubber drain hose. If I did not love the vehicle, it would be on craigslist already haha.
Carpet: [h=1]19333096[/h]
