H3 quit blowing hot air - Blower works
Korby7
Utah
I’ve had this happen to me from a thermostat failed to open not allowing it to come up to temperature. Cheap and easy fix. I’d start there if you haven’t checked that yet.
Happy Hummer
Wisconsin
Starting looking into the blend door, actuator assembly controls. Also, take the time to verify that it is indeed not a plugged up heater core.
poncho1965
Ridgecrest, California
Yep, was looking at the drivers side, there are three of them. Two worked but one did not. I removed it, and the heat is mysteriously working now. All functions work without this actuator installed. Heat, cold, floor, dash, defrost, you name it. So at this point I'm not sure. It's not the temperature blend door, or the one that diverts the air where you want it. Not sure of its function. ???
