H3 Upper Control Arms - How Would You Improve It?
Alpha X
The Motor City
In another thread I inquired changing the ball joint in the H3 Upper Control Arms. Looks like it's not really possible.
Upper Control Arm - Ball Joint?
https://www.hummer4x4offroad.com/forum/showthread.php/13674-Upper-Control-Arm-Ball-Joint
Let's assume, for a moment, you could make a totally new UCA for your H3. It has to be a bolt on solution, no welding on new frame brackets, etc.
What would you revise/change/improve?
1) Different Ball Joint? Silverado style, or something else that can also be rebuilt/replaced? (let's assume we can change the knuckle to accommodate a new style ball joint)
2) Would you retain or change the cam style adjustment where it mounts to chassis? Or, is there a better way to get some adjustability?
3) Cast and/or machined aluminum or fabricated/welded steel?
4) Anything else?
93ec8708353344338cb256c0d160144a_490.jpg3e5ce2089dec4388996028270873ef5e_490.jpgc4fa7c3244c34e82a595d811d3c3468c_490.jpg
I don't know that I'd go the distance of replacing the knuckles to accommodate a different UCA. My only wishes would be replaceable ball joints and bushings. For me, I don't see it as a huge opportunity since the UCA is only about $125 per side.
Traxx
PNW
Wonder how much trouble it would be just to swap in the front suspension from a Silverado? Never bothered to look under one but it would certainly make a lift kit easier.
atvspeed4
massachusetts
We have the CAD files for both and looked into building a subframe to do this but its not worth it. Funny enough, the H3 has much longer control arms and more wheel travel than the 99-10 silverado 2500/ 3500/H2. The geometry of the silverado suspension is better but not worth the battle.
We have a couple bags of rebuildable H3 balljoints sitting on the shelf ready to go into a set of arms but there really isnt much of a market out there unfortunately so it hasnt been an urgent project. Aftermarket H3 arms really should be "Stage 1" and "Stage 2".
Stage 1: rebuildable balljoint and replaceable or lifetime control arm bushings
Stage 2: rebuildable balljoint and cam washer delete
Alpha X
The Motor City
Thanks for the replies. Good info to consider. Silverado UCA/LCA will not swap without a lot of work, even then I'm not sure if it's possible.
atv - will you elaborate on the cam washer delete idea. How would it be adjustable?
