H3 H3 3.7 aluminium diff carrier conversion to Iron diff casing found in Alpha?
Angelos
Cyprus
Hi guys,
I am from overseas in Cyprus, and for the past three years, I have been looking to swap my aluminum front diff casing to the iron one. I wasn't able to find it and the necessary information but I think I just did? I attached two links.
If this is the one, what will I need to order with it to be complete? I want to use stock gears and diff and just change the housing. i really wish someone can help me out!
https://www.tubmangmpartsdepot.ca/p/AXLE-SHAFTS/59851268/25831502.html
https://www.ebay.com/itm/For-Hummer...-Differential-Carrier-/283613818145#vi-ilComp
Not quite, but it will work. For a 100% identical housing you need one from 2008 Alpha. That said, the only difference is the one you show has a provision for the locker wiring. The only thing you need to do is plug that hole.
Hi guys,
