2&1/2 hummer sale
fanugy
Phoenix, AZ
2009 H3t purchased from Copart for an LSA swap. Turns out frame is rusted through (from FL) and damage was metallic taped and then painted. It is an Alpha. Body is in good condition-very minor rust on underside of bed box near cab. Wheels and tires nice. Interior nice. Have not heard this one run and intake may possibly be SS Trailblazer and appears other mods were done to this motor. The grounds are rusted at two spots. Salvage title and needs a new frame to go forward.
Includes 2008 H3 Alpha (black) donor Hummer with good H3 frame and salvage title. Purchased from Copart in 2017 and repaired and installed LS2. Kids have been driving for last 7 years and 22,000 miles. Put on my lift for tr@ns repair when lift arm welds failed (don't buy Atlas 9k lifts) and dropped vehicle- frame and wiring harness and interior are good. Tr@ns and motor are removed with original block being set in place. Body pierced below driver feet, passenger side damaged. Hood looks near 100% good-damage mostly passenger side and rear bumper. Removed front grill and ARB bumper. I have 4 other trucks to build and still have kids in 2 other H3ts. Not getting back into Hummer game in near future. I also have a partial frame from an 07 H3 I purchased from Copart for a 4" lift that had burned. I cut the frame and kept the front half just in front of the frame splice (wish I had known more when I did that one). Can cut and include additional length of frame sides from this as well for stretch of 08H3 frame to fit 09H3t. Have lift from '07 available for extra 1500- knuckles, front diff drop brackets and center, NOT RANCHO.
Asking for 6,000. It is a project, but these T's are cool and they aren't making more!
Located in Phoenix area.
I have an independent broker I use to ship vehicles across country and can share his info, too.
I also have a front Dana 44 axle passenger drop and an ARB H3 rear bumper uninstalled if anyone is interested.
fanugy
Phoenix, AZ
Black Hummer photos, lift arm, gray alpha engine, frame section standing upright (one horn removed from passenger side)
fanugy
Phoenix, AZ
The black hummer does not have the transfer case installed either but it can come along if desired. I have the rear axle from the burnt 07 that has electronic rear dif. Also have the front diff, not locking. Also saved this transfer case if interested. I have a new grill, high gloss black that will accompany the H3t. I should also have uninstalled high lift leaf spring hangers from about 5 years ago (group purchase) and a set of upper control arms from Michigan Motor works never installed. the 08 & 09 have the upper dash tray.
fanugy
Phoenix, AZ
And I can fairly readily provide more photos of the 08 and 09 if desired. But I'm fat and getting older and crawling around sucks for photos :)
