- United States
I have a two part question. I know I the past there have been discussions about the keyless entry and the TPM system not working. The only thing those really pointed to was water getting into the BCM and corroding the common antenna. I've had the same issue, but the BCM shows no signs of ever having water damage. Antenna connector was clean and tight. Does anyone have any other suggestions?
Part two of my question is, if no one has any other ideas, can I swap BCMs from a second identically equipped H3 with no issue and no programming. I realize I will have to use the fobs originally paired with the replacement BCM, but beyond that, any other compatibility/programming issues?
Thanks in advance.
Thanks in advance.
