Calling all Gobi Owners!!
Hey all, so i recently came into possession of a gobi ranger with spare tire mount. Now i have a couple of questions. I have found that there is some pre installed wiring into the rack for what im assuming are rear mounted lights, am i correct? Also i have an additional gobi ladder, it will not work with a spare on the door. Just wondering if you all had any ideas what to do with it, and if there are any other pointers/advice about the rack please post it up. :)
Sent via Tapatalk
We put the ladder on Cotilo's truck recently and that H3X has that way oversized tire cover. And yes, I believe those wires are for rear lights.
08SolarFlareH3
Super Swampers
Finger Lakes, NY
Post up a pic of it and I can compare it to mine
I would assume this is the ladder he received
solar, you never cease to amaze me...the little things you pick up on is crazy...I didnt even know there was a difference in those 2 ladders.
Cgalpha, when I got mine Tim specified to them that I still wanted the other ladder so I wouldnt get that one. If you dealt with gobi directly or a company like expedition hardware or trail duty I would call them and let them know so they can talk to gobi.
Timgco
Hugh Hefner
Colorado
yep, that ladder without the curve, is designed for running without the spare. There are only 4 or 5 of those ever shipped as far as I know. If you bought it used, try and sell it and get the proper ladder. There are a couple guys that I'm sure would buy it. I'll even help you out on shipping of the new ladder. you can use the new box to ship it safely too.
If you are running a MT in a 35" tire on the stock wheel, you may want to order up spacers at the same time as your new ladder. this will give you just enough room to clear those lugs and also allow for more room to clean back there.
other than that, don;t overtorque the stainless hardware, use some anti-seeze if the hardware is stainelss to stainless. if you have the nylon locking nuts, you're OK and will not need the anti-seeze.
gobi install isntructions are on line if you need them.
hope that helps some. lmk if you need more info.
The wires running through the rack run front to back. hook your rear lights up to those pigtails at the rear. now they are stubbed out the front and ready to run down your apillars. get some weatherpack connectors for up front and mark them for each set of lights. if you ever take teh rack off for some reason, your wires are easy to unplug and re-connect when your done.
My mom ordered the rack new. I already have the normal with a spare on the door ladder. I havent decided if i want to sell the ladder or keep it. Thanks for the info. Im currently working on getting the proper fairlead because the distributor she bought it from sent the fj fairlead
Sent via Tapatalk
hope you get it all worked out...
Next time tell your mom to call this guy named Tim...he will get it right the first shot and if the manufacturer screws up then someone gets to yell at them and its funny. :hans:
Yea i prob should have mentioned him to her but i just mentioned in passing conversation that i wanted one, never expected her to actually order one haha
Sent via Tapatalk
