08 H3 Alpha door locks not responding to FOB
JasBass
Newport News VA
Afternoon All. New to the forum but not new to my H3, purchased new back in 08. I've been neglecting the door lock issue for a couple years now...no better time than now. Battery in the FOB is good and is the stock FOB, also used the other stock FOB to eliminate it being a FOB issue. I am assuming there is some kind of receiver/antenna/module that has gone bad and is not reading the signal? Thoughts? Appreciate the help and assist. Electronic gremlins like this are always my weak spot, hence the procrastination
JasBass
Newport News VA
Schwarttzy does a great video of how he repaired his.
Pulled out the BCM tonight, everything looks clean, no corrosion or anything visually of concern. Antenna connection is clean and snug. Threw a new battery in both fobs just to confirm. No resolution. Assuming at this point it is a BCM problem and needs to be replaced
Happy Hummer
Wisconsin
Please watch this you tube vid b4 spending money, time> (not my vid) lol! just a good primer on how the system was fixed by this method.
