WTS 1999 Hummer H1 HMCS
I was surprised to hear that Rich's truck had not sold yet. I knew that family wasn't in the best way. Who is Mike? I think Eric was trying to help sell the truck awhile back.
Sent Shane an e-mail but haven't heard from him. Not sure how interested I am but condition and price will determine that.
HUMMER INVESTMENTS
[o O IIIIIIII O o]
Black Hawk, SD
Truck includes these spare parts:
Update*
Included in the price is these spare parts:
1 Leece Nevill Starter Motor
Lot of AM General thermostats
Lot of 3 brush guards
1 AMG Volt Meter
2 tan seat covers, arm rests and head covers
1 AM General 5.5" speaker
1 AM General Tail Lamp Assembly
1 Interior Door Handle
1 Input Gear Assembly
1 AM General Fuel Gauge
1 stainless steel ctis braided hose
1 Exhaust Heat Shield
2 Runflat/Beadlock Assemblies
2 Radiator to Hood Foam Seals
1 AM General Temp Gauge
1 AM General Heater Resistor Circuit & Plug
1 AM General Aluminum Wheel
1 AM General Splash Shield
1 lot of AM General Gaskets
1 lot of Halfshaft Boots
1 16.5" wheel (backside)
1 rear jumpseat & seatbelts
1 Warn Front Winch Bumper
2 Front Non Front Winch Bumpers
1 6.5L AM General Oil pan
1 AM General Radio Antenna
2 AM General Heavy Brake Yokes
1 Power Mirror Switch & Wiring Harness
1 Set of "Diesel Fuel Only" Signs
1 Vacuum Pump Solenoid
1 Engine Block Heater Cord
1 Door Arm Rest
1 Lot Exhaust Gaskets
1 Lot Clampnut Hub Parts
1 Oil Pressure Gauge
1 Heater Control Valve & Connector
1 Transmission Pan Gasket
1 Lot Exhaust Clamps
1 Lot Intake Manifold Gaskets
1 Lot Alignment Shims
2 D-Rings & Brackets
2 Door Lock / Latch Mechanisms
1 Geard Hub Output Seal
1 Lot of Seat Belt Parts
1 Fuel Sender Unit
1 Power Steering Reservoir
1 Keyless Remote Receiver Assembly
1 Seven Pin Trailer Assembly
1 SMA Aluminum Dash Kit
1 Upper Control Arm, Bushing & Bolts
1 Status Box Assembly & Wire Harness
1 Fuel Injection Pump
1 Water Pump
1 Lower Radiator Tube
1 Pair Valve Covers
1 Lot Bumper & Frame Brackets
1 Lower Splash Shield (interior plastic)
1 Front Grey Headliner
1 Tan Front Window Trim Piece
1 Burlwood Dash Kit
1 Grote License Plate Replacement Light
1 Lot of CTIS Covers
1 Glow Plug Controller
1 Ignition Switch & Key
2 Automatic Window Motor & Assemblies
1 HVAC Blower Motor
1 Lot of Vent Line Hose
2 Two Inch Suspension Lift Spring Spacers & Front Springs
1 Window Glass Gasket Kit
1 Lot of High Pressure Hoses & Fittings
1 Lot Exhaust Wrap
1 Lot of Engine Gaskets
2 Heated Windshields
4 Brake Rotors
1 Front Brake Caliper Core
1 Lot of Drive Shaft Yokes
1 Lot of Wiring Harnesses
1 Fuel Sender
2 Differential to Brake Rotor Output Flanges
1 Lot of Tie Down Straps
1 Upper Ball Join
1 Lower Ball Joint
