Sway bar disconnects
JoshuaL
NEVERENDING ADDICTION
Mineral Bluff GA
Ok I'm looking at getting a set of JKS disconnects but I'm not sure which ones to get because my 3 has the rancho lift. Any help would be appreciated. Thanks
Portager
Silverado
Since I have broken two rear anti-sway bar linkages, I contacted JKS and they told me they had nothing for a Hummer. I guess I shouldn't have been surprised since their moto is "Off Road and Performance Upgrades for Jeep Vehicles".
Talk yo Trekker, he did a flex mod with jks quick disconnects, idk if it will work for rancho tho.
kflips
Virginia
I believe the JKS 3100 is the one you want. Both KS Trekker & Paladine I believe use(d) them. Issue is the abs brake line clip will need some type of extension given the added flex - I have an extended bracket holding my lines after one breakage late last year.
VegasH3
Western US
I don't think JKS even makes a rear dissconnect for the JK wrangler. It's almost unheard of to dissconnect the rear even for the hard core JK guys because of loss of stability. I'm not sure how it would be on the H3 given the front IFS, but for me stabilty would be a concern.
One other thing to consider. I would cycle the suspension....jack up a point on the frame, hitch or hi lift the tow hooks to the point where the tires are off the ground. Do this with the sway bars off. Watch for the ABS lines lacking enough length. It may not be enough...just double check so you dont have a huge mess to fix dealing with electronics. If your good on abs cable length then the JKS 3100s may work I gotta double check that they are long enough for the extended sway bar end links...
