New Rear Leaf Springs?
2007HummerH2
Maine
As the title says, I'm looking for replacement rear leaf springs. I'm tired of dealing with the dealership...all they do is grease them and say they supposed to make noise.
It's not so much the noise....the squeaking I can deal with, it's not that bad. It's the bang/clunk when I turn a corner that is bad. Also if you look at the passenger's side leaf, it looks bent. The leafs don't sit together very well.
I found place called The Suspension King and they offer new springs for $196.00. Does anyone else know of any other places that I can purchase a new set from????
Saw ur sig thought it was a 2. Those have coils...either way deavers wouldn't work well seeing you don't have a lift but I had squeaking with the stock leaves and powerwashed the hell out of them. Luckily that got rid of the noise...debris and mud got stuck in there
yes that is correct. I should of been more specific :)
H2's do not have leaves but was confused at first with his name. Before you go buy new ones I would try and clean em out...I had this issue for years, I was about to buy a new set and then I decided to powerwash the crap out of them and they never squeaked again...I would try that first.
GMparts direct is 127 per OEM spring
Always good to comparison shop. Direct's shipping charge is generally more than gmpartshouse so often the two prices tend to be close to each other. And gmpartshouse.com supports this forum so if they are competitive with price maybe their support of H4O can help be a deciding factor in the purchase. :)
