06PullUouT
- Kingsland, GA
Searched but no luck.... Is anyone running the scan gauge II and monitor tranny temp? If so, what is the normal range on the H3?
TIA
Deryl
TIA
Deryl
240??? dude that 20* away from completely cooked. Get an aux cooler.
I have had mine up to 240 if I recall correctly...these H3s run hot though.
As far as I know, the scan gauge tranny temp doesn't work on the Alphas.
"Ex Umbris Venimus"
Sent from my iPhone
Not sure about the Alpha but you should keep trying the X-Guage. I googled and found quite a few codes and I tried them all but none worked. A few weeks later I tried again and after 4 or 5 goes I got one of them to work.
Because I tow a lot I fitted the largest cooler I could find.
This is a Derale Racing Transmission Cooler with its own thermostat switch that turns on the fan @ 180.
I had to mount it vertically with the inlet/outlet at the bottom. I will see if I can find the installed photos and post them here also.
Cheers,
Arthur
| GAUGE | TXD | RXF | RXD | MTH | NAME | Notes |
| Elapsed Time Since Engine Start | 6C10F12211A1(01) | 0462051106A1 | 3010 | 000100010000 | ET | Seconds |
| Knock Retard | 6C10F12211A6(01) | 0462851106A6 | 3008 | 002D00320000 | KR | Degrees |
| Barometer V6 | 6C10F1221251(01) | 046285120651 | 3008 | 000300010000 | BAR | Inches of Mercury |
| Barometer V8 | 6C10F122119D(01) | 04628511069D | 3008 | 000300010000 | BAR | Inches of Mercury |
| Air to Fuel Ratio | 6C10F122119E(01) | 04628511069E | 3008 | 000100010000 | AFR | Ratio |
| Remaining Oil Life | 6C10F122119F(01) | 04628511069F | 3008 | 00C800330000 | OLF | % |
| Engine Torque | 6C10F12219DE(01) | 0462851906DE | 3010 | 000A00020000 | TRQ | Ft-Lbs |
| Trans Fluid Temperature (Exc Allison) | 6C10F1221940(01) | 046205190640 | 3008 | 00090005FFD8 | TFT | Degrees Fahrenheit |
| Allison Trans Fluid Temperature | 6C18F1221940(01) | 046205190640 | 3008 | 00090005FFD8 | TFT | Degrees Fahrenheit |
| Elapsed Time Since Engine Start | 07E02211A1(01) | 0462051106A1 | 3010 | 000100010000 | ET | Seconds |
| Knock Retard | 07E02211A6(01) | 0462851106A6 | 3008 | 002D00320000 | KR | Degrees |
| Barometer V6 | 07E0221251(01) | 046285120651 | 3008 | 000300010000 | BAR | Inches of Mercury |
| Barometer V8 | 07E022119D(01) | 04628511069D | 3008 | 000300010000 | BAR | Inches of Mercury |
| Air to Fuel Ratio | 07E022119E(01) | 04628511069E | 3008 | 000100010000 | AFR | Ratio |
| Remaining Oil Life | 07E022119F(01) | 04628511069F | 3008 | 00C800330000 | OLF | % |
| Engine Torque | 07E02219DE(01) | 0462851906DE | 3010 | 000A00020000 | TRQ | Ft-Lbs |
| Trans Fluid Temperature (Exc Allison) | 07E0221940(01) | 046205190640 | 3008 | 00090005FFD8 | TFT | Degrees Fahrenheit |
| Allison Trans Fluid Temperature | 07E2221940(01) | 046205190640 | 3008 | 00090005FFD8 | TFT | Degrees Fahrenheit |
I am interested in that synthetic Dexron VI if anyone can pass any info I would appreciate it.
Cheers,
Chook
Valvoline is listed as being a "fully synthetic" Dex VI. Whether it is truly synthetic, or simply made from hydrotreated group III base stocks like most "synthetic" motor oil, I don't know. Redline D6 is a true full synthetic that meets Dex VI specs. Personally I'm not a fan of Dex VI (polite way of saying it's total crap), but if you insist on using it the synthetics should do a better job.
Well, if Dex VI is hard to find and you really want the best, perhaps your local Allison trans distributor or big truck shop has Castrol Transynd or Mobil Delvac Synthetic ATF (NOT Mobil 1 ATF - they are different products). Technically, neither of these fluids meet Dex VI specs due to slightly higher viscosity (viscosity is similar to Dex III and most other ATF's), but they are superior in every way to Dex VI. The slight viscosity difference isn't an issue with the 4L60E, which was designed to use Dex III, and it works very well. It is a true fully synthetic fluid, using PAO (polyalpha olefin) base oil.
