- Scottsdale
My rear springs with 105,000 miles on them (and only driven to church on Sundays!) are sagging about an inch and a half to two inches vs. stock ride height. I need to address this of course.
So, I have a few options:
1) New OEM springs, about $140 per side plus shipping. Let's call it $330.
2) Re-arched springs, with another leaf, for $280. Reputable shop with a good history on re-arched springs
3) Cheating with extended shackles for $40.
So, can I cheat with just adding shackles on worn springs? That would presumably bring the ride height back up but what happens with performance of the springs?
Also, I'm comfortable (sorta) working with one spring at a time but I'm less comfortable removing both springs at one time and then dropping them off at the shop for re-arching. With less things attached on the rear end there's more room for error. The shop wants $325 for this labor.
Re-arching - I don't see bushings as an orderable item for the OEM bushings. I assume there are bushing at each end and I'd want to replace them, right?
So . . . pros, cons, guidance?
