Tranny cooler
I know at least 1 person has this. Is this a difficult mod requiring a bunch of additional cooling lines or just rerouting the lines threw the tranny cooler?
ReconH3
Guardian Angel
Raleigh, NC
If you have basic mechanical know how, you can Install it. I bypassed the OEM setup so that I don't get cross contamination if factory radiator fails.
"Ex Umbris Venimus"
Sent from my iPhone
Is there an easy way to tell which lines run to the tranny other than physically climbing under there and following them?
Chook
Brisbane (Australia)
Not sure if the Alpha is the same but on the RHS of the tranny you will see 2 metal pipes running forward near the exhaust. They run forward and connect in middle at the bottom of the radiator (as shown in the 4th pic on my other thread)
theindian
kc area
Would this upgrade void the powertrain warrenty, Im thinking yes, has anyone had any problems with warrenty on the trans if the radiator trans cooler failed and caused tranny problems, do they consider the rad. and cooler part of the drivetrain?
Chook or anyone else who has setup a transmission cooler, did you set it up so that it is in line with the radiator, like another small radiator, or did you set it up so that all of the transmission fluid only runs through the transmission cooler?
ReconH3
Guardian Angel
Raleigh, NC
I isolated mine to avoid contamination if OEM radiator fails. It's not as efficient as running both, but avoids tranny damage.
"Ex Umbris Venimus"
Sent from my iPhone
Chook
I run mine separately also but rather than cut through the rubber lines to fit the external cooler I bought new connectors. I disconnected the OEM & blanked them that way if the front cooler gets damaged I can undo the connectors and blanks and go back to use the OEM.
Anyway you could post up more details about it? I looked through the other thread and got the jist of ot.
Chook
If you look at this image in the background you can see the same connectors but they have blanks on them. If the other cooler fails, I can undo the blanks & use the connectors to re-connect the OEM cooler in the radiator. Connectors.jpg
4u33er
NYC
Once the car fully warms up my tranny temp seems to be almost a 1:1 to my coolant temp which is around 185f +\-
