What else to change when changing water pump?
ADOR
Las Vegas, NV
My wife's H3 now at 74K miles. The extended warranty expired when the odometer turned 65K miles. As luck would have it, the H3 is now having some problems. I took it for an oil change at a nearby dealer (Glendale) and informed the service advisor that I noticed some squeeking sound by the fan belt area. I was told that the technician found a leak in the water pump, causing the belt to be wet. Hence the squeaky sound. I was quoted $450 to replace the pump. Do that price sound fair? Anything else I need to change while they are working on the water pump?
ADOR
Las Vegas, NV
Thanks Recon. My Thermostat gave up at 57K miles (Jan. 2011). My extended warranty did not cover that. Ended up paying $436. Looking at the receipt right now. Part cost $45 from the dealer and $20 for coolant.
Thermostat. Get a quality one and not some cheapo no name brand.
"Ex Umbris Venimus"
Sent from my iPhone
Labor for the thermostat isn't cheap, as you found out, but I think I paid around $300 at a non-dealer for the work.
I don't think you have anything essential that you need to pay a dealer to replace. If they are replacing the belt then you should keep the old one as a spare. For the idler pulley, as Hunner mentions, it's not hard to do yourself if you're comfortable with work like replacing the belt. If not, it's a fairly inexpensive maintenance item.
ADOR, I assume you have an '06, is that correct?
deserth3
Conroe, TX
Wow. Do I understand this right? 300 and 430 for an I-5 thermostat. Thta's expensive. It's a realitively easy do-it-yourself install. Mostly is just messy.
Yeah, you gave me instructions on how to do it but I couldn't get the time and garage space to do it so I had to help make someone else a bit richer.
