New Hummer Title?
kflips
Virginia
So we all know 3.5L and 3.7L barely power our trucks, thus they are "Barely Powered" trucks!
5.3L H3's are called Alphas.
So I pose this question. If I'm swapping for a 6.2L V8 what will that one be called?
How about alpha dawg. Or. Nacho libre
davidh3
N/A
:corn: interesting thread.
How about....... H3B , B means Beta ;P [I have seen H3x H3T H3R-raing H3 Moab H3 Alpha]
Steve #1
TEXAS
You'll probably call it broke.
BTW: The 3.7 has resonable power for the H3 you probably just got the wrong trans.
Portager
Silverado
Too much?
I agree, not to be a party pooper but being totally honest! It is TOO MUCH as in too much torque for the drive train to survive and too much expense for what you get.
If you're starting with 2006 H3 you have the 3500 which produces 225 lf-lbs of torque (see below).
3500
The Vortec 3500, or L52, is a DOHC 3.5 L straight-5 in the GM Atlas engine family. It produces 220 hp (164 kW) and 225 lb·ft (305 N·m) of torque. The Vortec 3500 is optional on Chevy Colorado / GMC Canyon regular and extended cab trucks. It is standard on the Crew Cab Colorado/Canyon, and the Hummer H3.
If you have a 2007 or later I5 you have the 3700 which produces 257 lf-lbs of torque (see below).
3700
The Vortec 3700, or LLR, is a DOHC 3.7 L straight-5 in the GM Atlas engine family. Introduced in 2007, the engine has increased in displacement from 3.5 L (211 cu in) in the Vortec 3500 to 3.7 L (223 cu in), producing 242 hp (180 kW) and 257 lb·ft (348 N·m) of torque. This engine is offered with both an Aisin 5 speed manual and GM's HydraMatic 4L60e automatic transmission in the Chevrolet Colorado, GMC Canyon, Hummer H3, Hummer H3T and Isuzu i-370 trucks.
If you start with an Alpha then you would have the 5.3L LH8 which produces 320 ft-lbs of torque (see below).
LH8
The LH8 Vortec 5300 is a variant of the 5.3 L Gen IV small block V8 modified to fit in the engine bay of the GMT 345 SUV and GMT 355 trucks. It produces 300 hp (220 kW) at 5200 rpm and 320 lb·ft (434 N·m) at 4000 rpm. It has a displacement of 5,328 cc (325.1 cu in).
LH8 applications:
  • 2008–present Hummer H3 Alpha
  • 2009–present Chevrolet Colorado/GMC Canyon
Upgrading to the 6.2L L92 engine would provide 415 lf-lbs of torque (see below).
L92
The 2007 Cadillac Escalade has a 6.2 L Vortec 6200 (RPO L92) (≈376 cu in) engine. It is an all-aluminum design which, while still a pushrod engine, boasts variable valve timing, a first in a mass-produced non-overhead cam V8 engine. The system adjusts both intake and exhaust timing between two settings. This engine produces 403 hp (301 kW) and 415 lb·ft (563 N·m) in the GMC Yukon Denali/XL Denali, Sierra SLT (2009+), GMC Sierra Denali, and in the Cadillac Escalade. and makes an additional 2 lb·ft (2.7 N·m) torque in the Silverado and Sierra Vortec Max pickups, and 393 hp (293 kW) and 415 lb·ft (563 N·m) in the Hummer . It was also available in the Chevrolet Tahoe LTZ, with power ratings of 395 hp (295 kW) and 417 lb·ft (565 N·m) .
Applications:
  • 2007+ Cadillac Escalade
  • 2009 Chevrolet Tahoe
  • 2007+ GMC Yukon Denali/Denali XL
  • 2007+ GMC Sierra Denali
  • 2008+ Hummer H2
  • 2009+ Chevrolet Silverado 1500
  • 2009+ GMC Sierra 1500
So upgrading the 2006 to the 6.2L would represent an 84% increase in torque (this is just crazy!). Upgrading the 2007- from the 3.7L to the 6.2L would represent a 61% increase in torque (still crazy!). Upgrading the Alpha from the 5.3L to the 6.2L would represent a 30% increase in torque (better, but if will only last if you are very careful on the skinny pedal).
If you want to do something to get better than stock performance for a reasonable budget, look at the SEMA H3T Weekend Warrior concept truck.
"The H3T Weekend Warrior concept demonstrates the added extreme capability and functionality that can be accomplished with the H3T and a few weekends in the garage. Enhanced performance under the hood and from the suspension is due to the development work of HUMMER’s off-road engineers and the technology transfer from HUMMER’s championship-winning racing program.
Starting with a new H3T Alpha, engineers added nearly 70 horsepower to its 5.3L V-8 via components available through GM Performance Parts. They include LS2 cylinder heads (part number 12576063), a higher-lift camshaft (part number 12574519) and supporting components. Also enhancing performance is a custom, 3.5-inch exhaust system." :link:
These heads are ~$416 each and the camshaft is $218. Add to that a GM performance exhaust $299 off ebay and you're on your way to 370 HP and ~395 ft-lbs of torque which represents a 23% increase in power and torque for ~$2,000 versus maybe $20K to $30K for the 6.2L upgrade by the time you’re all done. This is more than enough power and torque to mess up the drive train of the H3 if you aren’t very careful, but vastly cheaper that the 6.2L Vortec upgrade. Granted the Weekend Warrior upgrade only provides a 23% power and torque increase as opposed to 30% for the 6.2L, but you get 77% of the upgrade for 10% of the cost.
SC_Hummer_Guy
Mr. Sexy Sugar Britches
North Charleston, SC; Angel Fire, NM
Whereas I can appreciate all of that, and boy did you do your homework on that one, I am making the required drivetrain changes I need to in order to support the engine's new capabilities. I will not be simply using this for offroading but also as a tow vehicle for my boat. So the raw power is kinda needed. However I def appreciate the insight into the power specs!
SC_Hummer_Guy
As far as the name goes.. The misses and I came up with this early last night when we couldn't sleep.
Since she is going to prolly buy an Alpha soon, we thought to name my truck H3 Omega. That way there's an Alpha and Omega. Thoughts????
Portager
Silverado
Maybe you should consider an H2?
abearden
N. Idaho
:giggle: When read the first post, that's what came to mind!
